Joysick Controll
Jaykie
FreeStyler Version: 3.01
Twitter: http://twitter.com/jaykie
Joysick Controll
Post by Jaykie »
This is from the old forum, not that old(4/7/2007), maybe someone can help the man out ;)
Maclover
Well sometimes I overide my pan/tilt with my joystick.... But the indicator on the pan/tilt window dosent go all the way to the corners and I dont get full movement. I tryed callibrating the joystick and it says that it iss going to the maximum x and y axies. So if anybody could help that would be amazing!
matt
Admin
FreeStyler Version: NULL
Twitter: twitter.com/hankosky
Re: Joysick Controll
Post by matt »
humm.. Thats kinda weird. Map your arrow keys on your keyboard to pan and tilt and see if you can go all the way..
Matt Hankosky
flickr.com/photos/mattxhank
matt wrote:....and see if you can go all the way.....
:mrgreen:
Kater
Post by Kater »
I've noticed this too. The reason is quite simple actually: your joystick is round, your pan/tilt area is square. Basically the circle is 'fitted' into the square so that the outer edges touch the middle of the borders of the square. That's your max.
The reason this doesn't show up when calibrating is because the calibration software shows you the corrected value, not the original value. A solution might be to impelement an algorithm that creates the same correction.
Lightman
FreeStyler Version: 2.95f
Post by Lightman »
Thanks for the help guys! Im now using the numeric arrows to overide.... not with the keyboard controls but theres this thing on windows xp pro that lets you use you numeric arros to conrol your mouse and you can adjust the accelleration on it and everthing! its pretty rad 8-)
Kater
Post by Kater »
The quickest way I found to control pan/tilt (or anything else) is using a touch screen. I could continue to rant for hours about how much fun it is using freestyler with a touch screen and a bcf2000, but you don't know what you're missing till you've tried it...
matt
Admin
Post by matt »
humkm i might have to barrow a touch screen from one of the golf courses i work at.
Matt Hankosky
^^^ He touches up peoples balls..... (cleans them)
matt
Admin
Post by matt »
DJ Support wrote:^^^ He touches up peoples balls..... (cleans them)
right.....
Matt Hankosky
