Hello,
has anyons made a file for this fixture? It had 2 different lights and i do nog know how i can manage this. I am also not very experienst user and maker of files.
Chauvet Vesuvio 2
- FreeStyler Version: Beta
Re: Chauvet Vesuvio 2
This one is also a bit complex as it is 2 fixtures in one and therefore not for beginners
I have created the basics for you.
It is 2 fixtures and you are manually to place the fogger part on the same address as the led part.
You are to add the color mixing as macros by your self as they are not defined.
(Don't forget to upload it here again when you have added them)
The UV control is placed on the WW fader.
Give it a try.
Give it a try.
I try it, thanx very much!
I try, but it is nog easy with macros.
I am not sure how the "color mixing" behave so it may be easier just to use the related fader
I have just started with the fixture. I try to change the dimmer to default 255. After saving this setting and restart it it is put back to the original setting. I do something wrong. Also the fogger works on both fixture files, but i can not control it in the appication with fogger control.
