Good morning . I tried to make the 60w renkforce LED spot in the FS creator but I didn't get it. can somebody help for this ?
https://www.conrad.com/p/led-moving-hea ... -w-1233874
renkforce 60w LED spot Topic is solved
- FreeStyler Version: 3.5
- FreeStyler Version: 4.1.6
Re: renkforce 60w LED spot
Attached is my attempt at a fixture for your instrument.
The following helpful programming windows are available via Windows -> All
Beam (Prism)
Colors
Gobos (I did not find images of the gobos so the Gobo window just uses numbers)
Lamp
Custom Sliders
Pan / Tilt (Note: the pan/tilt limits are configurable on the instrument. The fixture is set for a pan range of 540 and a tilt range of 270)
Your feedback is welcome.
Beam (Prism)
Colors
Lamp
Custom Sliders
thanksssss . i check it and its ok
