China Konuo Moving Spider Fixture
Enjoy!
- Twitter: http://twitter.com/#!/motsik
- FreeStyler Version: 3.4.6
Re: China Konuo Moving Spider
Dear Motsik,
Would you modify your Chine Konuo Moving spider fixture file to work with my 13ch/19ch Led mini spider light?
I appreciate you big help.
Thank you.
Thank you.
- FreeStyler Version: 4.1.6
If Motsik does not see your request and reply you may try this one (19 channel version).
If you try it please provide feedback.
After you add the fixture to the Freestyler workspace and select it click on the top menu item Window -> All
This should open these additional windows (you may need to move them around in order to see all of them):
Lamp
Pan / Tilt
Colors
Custom Sliders
Lamp
Pan / Tilt
Colors
Custom Sliders
Big thank to Rod.
