Sorry if I have mis-understood the manual, but the only real issues I've experienced is when I want to update a step in a sequence. I can only see a button to "add" a step... but I want to recall a step, say number 3 of a 10 step sequence, and then "update" that step once I've made the adjustments.
Is this currently possible and I've just misunderstood how it works? Or is this a feature request?
Also, it would be great if the "bug" where it adds an extra duplicate step at the end of each sequence created that you have to remove. It shouldn't add a step until I have clicked +
Updating Sequence
rth_discos
- FreeStyler Version: Beta
Re: Updating Sequence
Hej
I don't know if you have visit the wiki but there are a link to one of the many pages. There are much more info on the wiki about the sequences single stepping and so on.
Regarding the "+" then it works as it is intended.
When you open the editor then you already have the first step.
You don't add "the step" by pressing "+" you add a new one.
Meaning make a scene, press "+", make the next scene, and save.
You now have a sequence with two scenes.
If you give it an "+" and then save you will get an extra step and the last two will be identical.
