Anybody know if there's already a profile that would work with Chauvet Slimpar Hex (RGBAW-UV)? If not, I'l'l be happy to put one together, but I could use a couple tips, since Fixture Creator stops with 5 colors (RGBAW). What's the best way to add UV into the mix?
Thanks!
SlimPar Hex or Any RGBAW-UV?
- Just started using FS
- FreeStyler Version: Beta
Re: SlimPar Hex or Any RGBAW-UV?
You have a CW and a WW channel.
Use one of them for the UV as you only have one white.
Alternative you could use color wheel 2 with 10 colors and then place an UV icon as the first and 9 volume icons.
Thanks Jan,
Is there any way to account for the extra colors in the color pickers?
The color picker only control the RGB channals
- Commited FS Forum helper
- FreeStyler Version: 4.6
Hello, did you ever make a fixture for this? I have to use the SlimPar Pro H and it has the same 6 channel RGBAW-UV setup?
Thanks so much
Paul
Thanks so much
Paul
