Looking for a fixture file - Mini LED Moving Head - ebay Topic is solved
djkrazy
Hello all,
I'm looking for a fixture file. Only down side my light really don't have a name, Crazy Right? But true.
I bought a couple "Mini LED Moving Head" lights from Ebay. They came in, but with no names on the box.
I contacted the ebay seller, she said they make the light and it has no official name, they call it "Mini LED"
If you want to take a look at it, here is the ebay item ID: 161068197652 or 200924181278 and a link:
http://www.ebay.com/itm/Mini-Moving-Hea ... 2ec803b31e
I'm going to scan the manual and post the details soon..
I have started a Fixture File, but I don't understand all of that yet. So its a work in progress as these are my first DMX lights. Once I get a little further, i'll upload the file.
Just figure others may have this light or are in progress with a fixture file.
Thanks!
Thanks!
- djSupport
Re: Looking for a fixture file - Mini LED Moving Head - ebay
Please send the scans to support@thedmxwiki.com and I'll reward you by making the fixture!
Sent from my Windows Phone 8X by HTC using Tapatalk
- Kings
- Commited FS Forum helper
Yep...a profile does exist and I'll find the name for you (just can't remember right now).
- Kings
Search the forum for 'Sputnik' as I'm sure I've found it for someone else before.
- Kings
Chaucer mini spot!
- djSupport
If that's the case please send the manual anyway! I'm on my knees begging!
- Kings
- djSupport
Chavuet sell a cheap Chinese light?
djkrazy
Hey If the almighty master is offering to build the correct proper fixture file, i'm down!
If you need anything else, let me know. If you need a better scan of a page or whole thing, I can do it.
I'll also email this to support@thedmxwiki.com
Thanks!!!
Thanks!!!
Mini LED Spot Moving Head Light.pdf- (380.98 KiB) Downloaded 623 times
- djSupport
Yo, I can add the missing colours and gobos if you want but especially the gobos will need a clearer scan of that page
djkrazy
Not a problem, when I get back home ill get better scans for ya!
djkrazy
Here is a better pdf scan of that page.
I also get you a JPG file of the GOBOs, the forum wanted me to reduce the image size.
But it is better bigger.
I have a couple more DMX lights coming in, when they do I'll scan them for the WIki too.
Many Thanks!
Many Thanks!
Mini Spot LED Moving Head - 13 Channel.pdf- (1.85 MiB) Downloaded 362 times
- djSupport
I wont make them all though unfortunately this was a one off it takes a lot of time! I run the fixture creation service though which helps pay for the forum!
djkrazy
Any help, is better then zero help! And one of the other lights is a 3 chan. So it should be pretty easy.
- djSupport
best thing to do is open the file I made in fixture creator and correlate the info that's there and the info in the manual also read my page here http://www.thedmxwiki.com/the_very_simple_guide_to_dmx
edhtowntx
Im also in need of a fixture file for a mini gobo moving head from ebay, i tried to create one but i just dont understand the concept i get loss and frustrated, please help any help will be appreciated. Thank you!djSupport wrote:Please send the scans to support@thedmxwiki.com and I'll reward you by making the fixture!
stevef44077
I have the exact same fixture 13 channel Mini Spot light and also need the fixture file!!
