This thing is a BEAST of a hazer (but it better be for $1100 ). If your budget can handle it, you definitely want one of these. Hang time is awesome, and it sips juice - we play over 100 4-hour shows a year and use well under a gallon of fluid, and that's with leaving the hazer on and running the entire night!
Also, because I like to keep all my custom fixtures organized in my system and rule out the possibility of it being overwritten during an upgrade, the manufacturer is Two For Flinching. You can change this in the Fixture Creator if you want to
LeMaitre Radiance Hazer
- Hambone
- Band Member
- FreeStyler Version: Beta
- I Use FreeStyler for: Band
http://two-for-flinching.com
