Global truss library for Easy View 3D
- Commited FS Forum helper
- FreeStyler Version: 3.0.1
Just started learning Easy View 3D with the help of the tutorial on Wiki.com. I want to create a 10' X 10'' Truss stage with Global truss 12" square segments. For the height, I need 1 2 meter peice (which is in the objects library of Easy View), 1 1 meter peice and a 12" box corner. Unfortunately there are no 1 meter or Box corner objects in the Objects library. I don't see any way to modify the existing 2 meter truss object that is in the library and I can't find any resources online or files to download and install. Any help to get me started would be appreciated.
