any questions
German Monkey
any questions
Post by German Monkey »
I´m Christoph fro Germany.
I´m new in this Forum.
Since 1 month I use Easy View together with Cuelux DMX Software.
I´ve got some questions to use Easy View 3D:
1. where can I find a blinder fixture?
(stairville blinder 2000)
2. why have the strobe simulation always in the same speed?
3. Is it possible so simulate the Prisma from my Martin Mac250+ ?
here you can see my first simulation ;)
http://www.youtube.com/watch?v=Zr4YA2aG ... er&list=UL
matt
Admin
FreeStyler Version: NULL
Twitter: twitter.com/hankosky
Re: any questions
Post by matt »
There is a Fixture Creator that is just for EasyView. You can use that to make your missing fixtures, and adjust existing ones..
remember, Its a Visualizer, It will never be as good as the real thing. ;-)
Matt Hankosky
flickr.com/photos/mattxhank
German Monkey
Re: any questions
where can I find the fixture creator?
FreeStyler Version: 3.3.7
Re: any questions
Post by LJ_krede.dk »
the "fixture creator" is called ScanLibrary and should be in the magic 3d easy view folder (which should be in the Freestyler folder)
you can search the web for how to guides
Youtube video search for scanLibrary
/LJ_krede.dk
Aalborg, Denmark
German Monkey
Re: any questions
do I have to install freestyler?
Today I have only Easy View 3d installed.
And I can´t find the folder.
Re: any questions
Scanlibrary is a sunlite product like easy view so have noting to do with the FS install,,,
you can't find the folder or the program???
/LJ_krede.dk
Aalborg, Denmark
German Monkey
Re: any questions
in some threads I red that you must start freestyler at first and then Easy View.
Now I find a a programm in my folder. (but not in a freestyler folder)
is this the fixture creature?
matt
Admin
Re: any questions
Post by matt »
Yes! That is it. You can open an Existing fixture to see how one is made.
Matt Hankosky
German Monkey
Re: any questions
OK :)
But how can I change the Martin Mac250 fixture, so that it has not always the same shutter speed in Easy View ?
And how can I change the fixture, so that I can see the prisma effect in Easy View?
Is it possible to simulate different strobe speed and prisma?
