unofficial_supported_dmx_interfaces
DMX Interface Triangle Lights USB-DMX 512
Driver uDMX
Number of DMX Channels 512
Freestyler Version Running on 3.4.4
Tips: Remember when installing this particular interface to install the interface driver before you plug it in as you do with all new USB devices.
If you find your LED is slightly flickering when reducing or increasing the intensity then you should increase the output refresh rate in Freestyler setup⇒ output interface selection screen.
unofficial_supported_dmx_interfaces.1319430865.txt.gz · Last modified: (external edit)
