Setup Menu - External Control
DMX _ in
Please Fill in Text on this Topic
Joystick control
Keyboard shortcuts
With the Keyboard shortcuts it is possible to attach a function in FreeStyler to a certain Key so when this key is pressed then it will execute the function.
The key / function is set by highlight the wanted function and then pressing the wanted key.
It is possible to have more functions on the same key.
Note key setting is case sensitive and only one key stroke. This means that it is not possible to make a “o” + “Ctrl” or “o” + “Alt”.
Clear a key from the keyboard shortcuts
1)Clear all Keyboard shortcuts - You can do that if you press the Right mouse button on the shortcuts window and select “Clear all”
2)Clear a Single Key - you can do that by hightlight the Function you like to clear and press on “Backspace”
NOTE: so you can not use “Backspace” as a Shortcut.
NOTE: Also “Spacebar” presses the last button you have selected with the mouse.
This happins with: Fast cuelistbuttons, Release all, disable buttons, tap sync, manual trigger, play/Stop, Run, Stop, back and go.
Midi control
Touchscreen
Enttec wings
