setup_menu_external_control
Setup Menu - External Control
DMX _ in
Please Fill in Text on this Topic
Joystick control
Keyboard shortcuts
With the Keyboard shortcuts it is possible to attach a function in FreeStyler to a certain Key so when this key is pressed then it will execute the function.
The key / function is set by highlight the wanted function and then pressing the wanted key.
Note key setting is case sensitive and only one key. This means that it is not possible to make a “o” + “Ctrl” or “o” + “Alt”.
Midi control
Touchscreen
Enttec wings
setup_menu_external_control.1310371603.txt.gz · Last modified: (external edit)
