sequence_understanding
Sequences Understanding
IMPORTANT NOTE
This article assumes you're running FreeStyler on a PC using a little endian processor (x86 core) You may have to consider swapping the data on a big endian processor (need cross check)
Word0: Number of steps contained in the file
0x0200: Sequence has 2 steps
all steps are using 1618 words (1 + 1 + 1536 + 79)
Word1: Time for the fade (multiplier for 500ms)
0x0100: (fade time is 500 ms)
0x0300: (fade time is 1500 ms)
0x0A00: (scene time is 1000 ms)
0x0D00: (scene time is 1300 ms)
  • First word is the DMX value for the channel
From 0x0000 to 0xFF00
(0x0100, 0x0200, …, 0x7F00, 0x8000, …, 0xFE00, 0xFF00)
  • Second word is the usage of the DMX channel
0x0100 = Fade
0x0200 = Snap
0x0300 = OFF
  • Third word seems to be unused for now
Always 0x0000
How can I see/edit the sequence file content
Get an Hex editor such as PSPad for example and open the file in HEX format.
HEX content of the sequence file
In this example, the sequence has 5 steps. 0x0500
In step1
  • Fade time is 500ms 0x0100
  • Scene time is 1000ms 0x0A00
  • Channel1 is 255 snap 0xFF00 0x0200 0x0000
  • Channel2 is 255 fade 0xFF00 0x0100 0x0000
  • Channel3 is 255 fade 0xFF00 0x0100 0x0000
  • Channel4 is 255 snap 0xFF00 0x0200 0x0000
  • Channel5 is 255 fade 0xFF00 0x0100 0x0000
  • Channel6 is 255 snap 0xFF00 0x0200 0x0000
  • Channel7 is 255 fade 0xFF00 0x0100 0x0000
  • Channel8 is 255 snap 0xFF00 0x0200 0x0000
  • Channel9 and follow are unused
sequence_understanding.1269933313.txt.gz · Last modified: (external edit)
