Sequences Understanding
IMPORTANT NOTE
This article assumes you're running FreeStyler on a PC using a little endian processor (x86 core) You may have to consider swapping the data on a big endian processor (ned xcheck)
Word0: Number of steps contained in the file
0x0200: Sequence has 2 steps
all steps are using 1618 words (1 + 1 + 1536 + 79)
Word1: Time for the fade (multiplier for 500ms)
0x0100: (fade time is 500 ms) 0x0300: (fade time is 1500 ms)
0x0A00: (scene time is 1000 ms) 0x0D00: (scene time is 1300 ms)
- First word is the DMX value for the channel
From 0x0000 to 0xFF00 (0x0100, 0x0200, …, 0x7F00, 0x8000, …, 0xFE00, 0xFF00)
- Second word is the usage of the DMX channel
0x0100 = Fade 0x0200 = Snap 0x0300 = OFF
- Third word seems to be unused for now
Always 0x0000
How can I see/edit the sequence file content
Get an Hex editor such as PSPad for example and open the file in HEX format.
In this example, the sequence has 5 steps. 0x0500
In step1
- Channel1 is 255 snap 0xFF00 0x0200 0x0000
- Channel2 is 255 fade 0xFF00 0x0100 0x0000
- Channel3 is 255 fade 0xFF00 0x0100 0x0000
- Channel4 is 255 snap 0xFF00 0x0200 0x0000
- Channel5 is 255 fade 0xFF00 0x0100 0x0000
- Channel6 is 255 snap 0xFF00 0x0200 0x0000
- Channel7 is 255 fade 0xFF00 0x0100 0x0000
- Channel8 is 255 snap 0xFF00 0x0200 0x0000
- Channel9 and follow are unused
