sequence_understanding
Sequences Understanding
IMPORTANT NOTE
This article assumes you're running FreeStyler on a PC using a little endian processor (x86 core) You may have to consider swapping the data on a big endian processor (ned xcheck)
Word0: Number of steps contained in the file
0x0200: Sequence has 2 steps
all steps are using 1618 words (1 + 1 + 1536 + 79)
Word1: Time for the fade (multiplier for 500ms)
0x0100: (fade time is 500 ms)
0x0300: (fade time is 1500 ms)
0x0A00: (scene time is 1000 ms)
0x0D00: (scene time is 1300 ms)
  • First word is the DMX value for the channel
From 0x0000 to 0xFF00
(0x0100, 0x0200, …, 0x7F00, 0x8000, …, 0xFE00, 0xFF00)
  • Second word is the usage of the DMX channel
0x0100 = Fade
0x0200 = Snap
0x0300 = OFF
  • Third word seems to be unused for now
Always 0x0000
How can I see/edit the sequence file content
Get an Hex editor such as PSPad for example and open the file in HEX format. HEX content of the sequence file
sequence_understanding.1269276368.txt.gz · Last modified: (external edit)
