Sequences Understanding
Word0: of the file indicates the number of steps contained in the file
0200: Sequence has 2 steps
all steps are using 1618 words (1 + 1 + 1536 + 79) Word1: Time for the fade (multiplier for 500ms)
0100: (fade time is 500 ms) 0300: (fade time is 1500 ms)
0A00: (scene time is 1000 ms) 0D00: (scene time is 1300 ms)
- First word is the DMX value for the channel
From 0x0000 to 0xFF00
(0x0100, 0x0200, …, 0x7F00, 0x8000, …, 0xFE00, 0xFF00)
- Second word is the usage of the DMX channel
0x0100 = Fade
0x0200 = Snap 0x0300 = OFF
- Third word seems to be unused for now
Always 0x0000 Word1540 to Word1617 (included): Behavior not understood. Values are not changing whether cues or buttons are used. I have today no clues for that.
