sequence_editor
Sequence Editor
A sequence can be considered as an amount of several snapshots, where each DMX channel will take the desired value.
Steps can then be played during live shows, stepped either by a time frame or thanks to the music beat.
This editor is able to save / load / edit the sequences
Open the sequence editor
or use the shortcut in the toolbar
The sequence editor will open
Create a sequence
When you launch the sequence editor, it is ready to take snapshots, so there is no need to start a new sequence. You are able to add steps thanks to the add scenes button.
When you want to create a new sequence, use the new sequence button.
Save a sequence
Once you have take several snapshots, it's time to save your current sequence so that you will able to play it during your shows. Clic on the savebutton. In case you don't want to override an existing sequence, you can use the save asbutton.
Enter a filename, tick the add to cue and add to buttons options, and clic the save button.
NOTE: you can manage your sequences by creating folders and more.
Load a sequence
You can load an existing sequence and edit it (insert steps, change fade, time, etc).
Clic the load button and choose the file you want to edit.
NOTE: This also allow you to move seequences from a location to another (from a PC to another for example).
Edit a sequence
In order to edit a sequence, move from a step to another thanks to the browse buttons.
You can choose to
  • insert insert a step before the current one.
  • delete delete the current step.
  • set set the current values to all steps.
It's also possible to use shortcuts to copy, cut, paste or undo the current step. edit
Run a sequence
Once you are proud of your design, it's time to test it.
You can use the preview button.
sequence_editor.1269899039.txt.gz · Last modified: (external edit)
