playback:cue:playback_sequence
Playback Sequence
This tutorial explains how to Run a Sequence and some other Options what you can do with your Sequences
But you can do more with the Cue window:
- Cuelist buttons
- Control sequence by time (elapsed / realtime):
- Submasters
Click on the “Cue” icon on the toolbar . The following screen appears:
Playback a Sequence
- Go to the menu and click on “insert sequence” Or press on
- Select the scene or sequence you would like to insert in the list and drag it to the cuelist.
- Repeat until all desired sequences are loaded into the cue
To play a sequence, press on the corresponding sequence button.
All sequences can run a the same time with LTP (latest takes precedence).
(Make sure you have configured the “Multiselect” Setup→Freestyler setup→Preferences→Extra options or keyboard shortcut) Set the playback speed off a sequence by sliding the corresponding speed slider to the desired speed.
Right click on it to set it back to 100%
Other Cue Functions / Options
Release all and Disable all Buttons if you Play a Sequance, On or off Default=Off
Repeat sequence or single play, Default=Repeat
Reverse: Play the sequence Forward or backward, Default=Forward
Play random scenes from the sequence, On or off Default=Off
Restore DMX values when sequence stopped, On or off Default=Off
Enable or disable Sound to light on the Sequence, Default=Disable
Let Sequence react to Manual tap and Tap sync, On or off Default=On
Disable or enable all Fades from the Sequence, Default=Enable
If you press on the you will get the Cue options.
- Insert sequence - Insert a Sequence to the Cuelist
- Save Cue - Save the Cuelist you made
- All speed to 100% - All speed faders back to 100%
- Always start with 1st Scene -
- Enable timecode -
- Loop all Sequences -
- Compact view -
- Cuelist Buttons Visible -
- Clear list - Clear Cuelist
Here you have some other controlls.
- Masterspeed
- Release all - Release all manual override
- Disable buttons - Disable all Override buttons
- Manual trigger -
- Tap sync -
playback/cue/playback_sequence.1319044848.txt.gz · Last modified: (external edit)
