Fixture Creator - The "Formula" Feature
The new “Formula” feature can both greatly simplify a fixture's Macro window and add more controls at the same time.
Variables
- GIx (GI1, GI2, GI3…. or GI01, GI02, GI03…) → Gobo Index number
- CIx (CI1, CI2…. or CI01, CI02…) → Color Index number
- CHx (CH1, CH2, CH3…. or CH01, CH02, CH03….) → The fixture's Channel number
NOTES:
- GIx and CIx are indexed values and only go in the order 1, 2, 3, 4…. (sequential whole numbers)
- GIx and CIx correspond with the number of Gobos and Colors you have set on the “Fixture Config” tab. If you have specified that Gobo Channel 1 has eight gobos, then GI01 (or GI1) will vary between 1~8 according to whichever Gobo is currently displayed. Likewise, if you have specified your Colorwheel has 12 colors, then CI01 (or CI1) will vary between 1~12.
- CHx corresponds to the channels you have setup and described on the “Fixture Config” and “Channel Description” tabs.
Operators
- ** + ** → Addition
- ** - ** → Subtraction
- ** * ** → Multiply
- ** / ** → Divide
- ** ( ) ** → Parenthetical Ordering
Usage
Formulas are written in standard programming syntax. Computations on the right side of the “=” are assigned to the variable on the left side.
NOTES:
- Spaces are NOT permitted in Formulas!
- CH01 = 6 + (GI1 * 6) ← WRONG, will not work.
- CH01=6+(GI1*6) ← CORRECT, will work. (No spaces in Formula.)
- Only ONE “=” is permitted in a Formula. Using multiple “=” in a Formula will yield unexpected results.
- ** CH01=48 ** ← CORRECT, will work. (Assigns the value “48” to Channel 1.)
- ** CH01=CH02=CH03=48 ** ← WRONG, will not work. The programmer is trying to assign the value “48” to Channels 1, 2 and 3 simultaneously, but this will not work.
Example 1:
CH01=48
Example 2:
**CH01=GI01*16 **
Example 3:
**CH01=16*(GI01-1) **
Example 4:
**CH01=16*(GI01-1)+4 **
Example 5:
**CH2=CH1 **
Summary
The new “Formula” feature in Fixture Creator and FreeStyler helps to both simplify macros and add more control. Formulas must be written following strict syntax rules, otherwise they do not work.
