Using the Formula function.
It is assumed that the reader are familiar with the basics in creating a fixture.
Loading values into various channels.
The target is here to control a fixture with 7 beams which each have a lot of macros.
In this example the JBSYSTEMS Taurus Led are used.
The macros are identical for all 7 beams and can’t be configured individually because there are to be used 50 macros for each beam.
In total this gives 350 macros and the max number of macros are 150.
The basic idea is to set the macro value into one channel and then load from there it into the wanted beam channel.
The fixture is a 9 channel fixture but for this example an extra dummy channel is used to contain the macro set value.
It is not necessary to use this extra dummy channel. One of the beam channels can be use but this have some advantages and some disadvantages.
If Beam 1 channel is used as set channel then it will be possible to see direct what color / chase is selected.
Beam 1 is the last on to be programmed and if manual control is used then Beam 1 will always change when a macro is set.
Beam 1 Set.
Beam 1 copied to Beam X
If Dummy channel is used then the no Beam is change before the change is loaded into the beam.
But it is not possible see the beam change before it is loaded and the fixture occupy an extra channel.
Dummy Set.
Dummy copied to Beam X
The DMX table is 7 identical color / chase tables.
The fixture is a 9 channels and here the “Total” channels are set to 10 so there space for the Dummy Channel.
In the macro table all 50 are filled in.
Depending on channel 1 setting the Beam control will either be Color or Chase so therefore are channel 1 values also set.
Note there are some icon that have no values. This is either used as title or blanks.
The last 7 macros are used to load the value from the dummy channel into wanted beam channel.
The Formula field contains CH2 = CH10 which means that the value from channel 10 is copied into channel 2, (Beam 1)
The fixture control will then look like this.
How does this work.
Press one of the Chase or Color icons.
Then press one of the Beam icons.
Note: For this fixture it is so that all beams will either be in color or chase mode.
It is not possible to have one in chase and one in color.
The last pressed icon determine the mode.
More to come
