fixture_control:macro_panel
Panel Description - Macro Panel
The macro panel only consists of icons to press.
In this example the lens icons are also present in the Beam Panel.
This is due to the show in function that can be configured in Fixture Creator.
All macros that are defined with Fixture Creator will be shown in macro panel. The show in function opens for and additional access to the icon from other panels.
The row starting with Fan off, is only present in the macro panel.
The icons in the macro panel may be related to functions and faders in other panels.
And additional some of them can be complex to use because the icon function can consist of a formula and thereby in some cases two icons are to be pressed to set a value.
Beam Panel
Note the red X in the macro panel. This is shown when an image is not attached to a macro in the macro table.
Fixture Creator - Macro Configuration
fixture_control/macro_panel.1318927549.txt.gz · Last modified: (external edit)
