Midi Interface
What is MIDI
As the name says musical instrument and is original made for playing music.
This gives some terms that are related to music but they can be compared a bit with DMX
| DMX Protocol | Max Value | Midi Protocol | Max value |
| Universe | 1 | channel | 16 |
| Channel | 512 | Note | 127 + 0 |
| Value | 255 + 0 | Velocity | 127 + 0 |
Note and Channel in DMX are alike though in DMX 512 are available, then in midi only 127 + 0 are available.
Midi Controller
As MIDI controller every thing that can generate a midi signal can be used. Controllers comes in many shapes some with faders, some just with buttons but in the more special end also keyboards for playing music can be used it just need to be able to generate a midi signal.
As alternative merge sw. Bome’s midi translator can be mentioned but there must be more it is just to search for it.
Midi-ox setup.
More Midi Ox setup See. midiox
Midi and FreeStyler
This means that one button is assigned to select page1 and an other to Page2. By pressing these two buttons the mapping page will shift and thereby the functionality of the BCF.
BCF2000
Encoder section
8 x Encoders
8 x build-in buttons
2 x 8 Buttons
Fader Section
8 faders
Button section
4 buttons
using_bcf2000
How to Setup
Start FreeStyler
1. Expand External Controls, select Midi Control
2. Select Midi Input device
3. Select Midi Output device - Optional: used for device feedback (LEDs, Motorized Faders, etc.)
4. Click the Start button
5. Click the Edit button
6. Scroll down and find the function you would like to assign a midi function to.
7. Click in the “Note” section of the function.
8. Using your midi controller, push the button or turn the knob that you want to control the selected function.
9. Freestyler should be listening for the note and you should see it appear next to the save button.
10. Select eventually Page mapping. Here all functions are mapped to Page 2
11. Continue assigning midi functions to buttons or knobs as you wish.
12. Once finished, click “SAVE”.
Page
In all the other page settings the note and the mapped function is only available on the selected page.
Example could be a button that has note 10 with page 1 selected it is “Open Gobo” with page 2 it is “Open Color”, with page 3 selected it is “Open Pan/Tilt and so on.
Note monitor
In the picture above it shows note 101 with a velocity 0.
Option
