Midi Interface
What is MIDI
As the name says musical instrument and is original made for playing music.
This gives some terms that are related to music but they can be compared a bit with DMX
Dmx ——–Midi
Universe – Channel —- 16
Channel — Note ——–127 + 0
Value ——-Velocity
Note and Channel in DMX are alike though in DMX 512 are available, then in midi only 127 + 0 are available.
Midi Controller
As MIDI controller every thing that can generate a midi signal can be used. Controllers comes in many shapes some with faders, some just with buttons but in the more special end also keyboards for playing music can be used it just need to be able to generate a midi signal.
As alternative merge sw. Bome’s midi translator can be mentioned but there must be more it is just to search for it.
Midi-ox setup.
More Midi Ox setup See. midiox
