external_control:midiox
Midi-ox setup.
What is Midi. MIDI stands for Musical Instrument Digital Interface Musical Instrument Digital Interface.
When more Midi devices are to be used there may be the problem that they don’t have extra midi inputs and outputs to interconnect with.
If the midi devices has an additional usb interface then this can be used to combine more devices with using a software tool / driver as Midiox.
One midi socket are used to merge the midi devices into one channel.
The other socket are used to split the return signal out to all the devices.
external_control/midiox.1317637335.txt.gz · Last modified: (external edit)
