external_control:go-back_on_encoder
Tutorial how to have GO and Back on a encoder/slider
first you need some stuff before you can configure Bome's midi translator.
1) a midi controller with encoders or sliders, that send CC# note's.
2) Midi Yoke or loopbe, to create a Virtual midi connection between Bome's and FS.
3) bome's miditranslater PRO
oke if you have all of this you can configure Midi bome's
oke first you need to set the correct midi in and midi out
So midi in should be your Midi device, and midi out Midi yoke1 or Loopbe1
now go to the Options and set Midi trhu enabled.
now if this is done you need to create a new Preset.
press on the far left button (looks like a star) to create a new preset.
as you see on the image its called new preset, but you can also give it a other name.
now you need to add a Translator, so press on the Right + sign “add new translator”
as you see on the image its calls “New Translator”.
now dubble click on the New translator and ther will pop up a new window.
as you see i enabled the “Capture midi” box.
now press on the input field next the the box and rotate or drag the Encoder/slider.
you will see midi note's apeare in the input field.
some thinglike this “B0 01 PP” and as you see i changed the PP to oo this is importent!!!
now if you done this you need to go to the Rules tab.
Now on this tab you need to add script you see on the image.
this can be a little tricky but just try and you will see it.
now if this is done you need to go to the Outgoing tab.
as you see i used a Key stroke emulation.
this means i change a Midi signal to a Keybaord key.
as you see on the image i added the key “Q”
now apply this, Apply is Realy important otherwise it will not be saved!!!
now you just made one translator and to make this feature work oke you need two translators for each encoder or fader you like to have this feature on.
so you need to ass a Second translator with the same input Note in the example: B0 01 oo
the rule this time is a little bit differnt:
if oo⇐gc then Goto “back”
gc=oo
exit rules, skip Outgoing Action
Label “Back”
gc=oo
oo=oo*21
pp=oo/127
if gd==pp then exit rules, skip Outgoing Action
gd=pp
and the output singnel is again a key stroke emulation only not the same key button a other one so “A”
now open Freestyler and go to the external controls, and then the keyboard shortcuts.
now search for the submaster GO 1~20 and Submaster back 1~20.
now on Submaster Go1 you put the Key “Q” submaster back you put the key “A”
and iff this is inverted just, invert the Q and A.
Keep in mind you use a Keyboard key so Freestyler must be on top otherwise windows will not send the keyboad key to freestyler.
external_control/go-back_on_encoder.1344693308.txt.gz · Last modified: (external edit)
