external_control:go-back_on_encoder
Tutorial how to have GO and Back on a encoder/slider
first you need some stuff before you can configure Bome's midi translator.
1) a midi controller with encoders or sliders, that send CC# note's.
2) Midi Yoke or loopbe, to create a Virtual midi connection between Bome's and FS.
3) bome's miditranslater PRO
oke if you have all of this you can configure Midi bome's
oke first you need to set the correct midi in and midi out
So midi in should be your Midi device, and midi out Midi yoke1 or Loopbe1
now go to the Options and set Midi trhu enabled.
external_control/go-back_on_encoder.1344687115.txt.gz · Last modified: (external edit)
