create_sequence:sm_led_tutorial
Led Submaster Tutorial
Here i'm going to show how to Program your ledpars with the Submasters, and the whole idea about Programming with Atributes.
And the atributes where going to use with the Ledpar are:
Main:
  • Colors
  • Dimmer
Other:
  • Auto Speed
  • Address ID
The first example i make is a Ledpar that only haves a RGB channel.
Also the RGB channels are Related to the Atribute “Colors”
I'm now Going to show a Sequence thats made Default by Freestyler IFF you only drag the RGB Fader on the Left Slider panel.
Made out of 3Steps
Step 1 - 3
The only bad News is This is Wrong, or allmost Correct. it should look like this.
As you see the RGB channels are on FADE on each Step.
This way your Sure that if you Control the RGB channels With the Submasters That on Each step Nothing Strange can happin.
This is Just a Example you can also make you own Sequence BUT be Sure that on all the steps you have the RGB channels on FADE.
TIP: If you Press on FADE button you Can Switch between Fade, Snap or OFF.
create_sequence/sm_led_tutorial.1325105587.txt.gz · Last modified: (external edit)
