Community Downloads Section
Sound 2 FreeStyler DMX
Sound 2 FreeStyler DMX is a tool to synchronize the speed of DMX lights to FreeStyler by the use of a MIDI sync clock. A MIDI clock from e. g. Traktor or a MIDI sync clock supported DJ mixer. Click here to download and more info
LuaFs - Lua Scripting
LuaFs - LuaScripting for FreeStyler Click here to Download LuaFs 0.2
120DB.co.uk Addons and Android Remote - Mattotone
Collections of Freestyler Addons, Android Applications and more. Click here to visit website
Auto-Strobe Timer - Mattotone
iPhone / iPad Remote
Use your iPhone and iPad to control FreeStyler Click here for iPhone/iPad Application https://www.youtube.com/watch?v=cKCuloP21tA for videos
Sound 2 Light
Easy Freestyler Interface
Simple menu driven FreeStyler interface. organise your cues into a tree/folder type structure for easy playback. Click here to Download
Theater Cue Stack - Mattotone
Images for Fixtures - mmax
FreeStyler DMX for Beginners
Joystic, gamepad or arrows
Joystic for FreeStyler Control Pan / Tilt movement, set position and get the device, adjust the speed Pan / Tilt movement, especially in the use of balls and weddings. Click here to joystick 1.0.0.2
