Community Downloads Section
Edit this page to add your FS integrations/tools/images
LuaFs - Lua Scripting
LuaFs - LuaScripting for Freestyler Click here to Download LuaFs 0.1
Telnet Server [Beta 4]
PDA Control Interface
FS configuration tool
Simple tool that allows editing the freestyler.ini using a graphical user interface. Click here to Download the FS configuration tool
Auto-Strobe Timer - Mattotone
iPhone / iPod touch Remote
Use your iPhone and iPod touch to control FreeStyler Click here for iPhone/iPod touch Application YouTube.com/iFSControl for video tutorials
Sound 2 Light
Easy Freestyler Interface
Freestyler AutoUpdate - Mattotone
AutoUpdate for FreeStyler, will check the server to see if there is a newer update Download AutoUpdater Instructions & comments]
Simple Cue Stack - Mattotone
Images for Fixtures - mmax
Freestyler DMX for Beginners
