I'm experiencing issues interacting with buttons in the sequence panel.
luinautic
FreeStyler Version: 4
I Use FreeStyler for: Band
Post by luinautic »
I would like to describe my issue, and I'm not sure if anyone else has noticed it before...
When I'm recording the sequences and movement steps of my lighting fixtures, in previous versions I could hold down the increase or decrease button for the time between "crossfade" and "duration." Now, it's necessary to click repeatedly until reaching the desired time...
I understand this is a minor detail, but it's very tiring. It would be ideal to be able to directly input the time in SECONDS and milliseconds, or, if possible, to hold down the button so that the time selection process increases or decreases automatically without so many clicks.
Can anyone help me with this?
THNKS :D 👍👍👍👍
FreeStyler Version: 4.1.7
Re: I'm experiencing issues interacting with buttons in the sequence panel.
Post by Rod_Horning »
I've noticed that also. Please submit a BUG report - Open Quick-Links and click on the first menu item.
Note. The Bug Tracker requires its own user id and password (which may be the same as for this forum).
