Wired connection wirelessly
geddydawg
Just started using FS
Post by geddydawg »
I have Freestyler installed on a laptop at the back of the stage, and a 3 pedal generic foot pedal at front of stage, where I play. The 2 are connected via a 25’ usb cable. Everything works with Freestyler for scene changes just as it should. But, I’d like to have the connection of the (front of stage) pedal to the (back of stage) laptop done wirelessly. Is that possible? Via either a wireless usb connection, or done by Bluetooth, or would I need a different foot-switch to start with? Any ideas would be so appreciated.
FreeStyler Version: 4.1.7
Re: Wired connection wirelessly
Post by Rod_Horning »
bhphotovideo.com has a few wireless USB extenders that might meet your need. Not cheap though. On their site use search term wireless USB extender.
geddydawg
Post by geddydawg »
Thank you for the tip! I’ll go check out their website and search!
geddydawg
Post by geddydawg »
I didn’t see anything on that website that would wirelessly connect a foot-switch to the laptop with the lighting software on it. A 25’ distance connection done via usb, done wirelessly.
I was thinking possibly something like the Airturn Quad 500, with a Bluetooth connection. Any thoughts on that?
Days has the ability to map the foot switches to keyboard characters. That’s what I’m using now with the generic wired keyboard, with the usb cable. Does the Airturn via Bluetooth give the wireless version of what’s being looked for?
https://www.airturn.com/products/airtur ... 2134755587
Based on my understanding of the information from the link you provided it does look like this might work. It would probably use the MIDI interface. The video suggested giving the company a call - that should be a good first step.
Also, this might be of some help.
https://www.smallnetbuilder.com/everyth ... ver-again/
Return to “Windows Apps”
