Using Multiple Cues that fire both cues together?
Group Therapy
FreeStyler Version: 4.1.6
Post by Group Therapy »
I've already searched so I apologize, but I have not found the answers and its still not working.
I have been a freestyler for a long time, but just basic stuff, LED par cans.. Moon flower effects, chase scenes.. Solid color scenes! Easy stuff. I have since acquired moving head fixtures which I understand somewhat, No worries. But now I want to work these lights into solid scenes from their own cue, ex: while running a solid color scene I want to be able to click the newly created moving scene cue to play with the solid color scene and so one with other chase scene.
I have enabled Cue Muliselect Always but it still kills the previous cue once selected while using the cue list. So the color scene shuts down although it still appears cued and the next cue starts.? If I deselect the moving light cue then the solid color scene continues..
This cannot be that hard, I've tried the sub master stuff, never used it before.. So I'm learning but I am having no luck there either..
Thank you for your time!
FreeStyler Version: 4.1.7
Re: Using Multiple Cues that fire both cues together?
Post by Rod_Horning »
Would you create a backup, zip it, and post it. Let us take a look and maybe we can see the issue.
Thanks.
john25
Post by john25 »
Use Separate Cue Lists via the Submasters (Sequence Player)
Make Sure Fixtures Don't Conflict
oyostepper.de sells closed-loop stepper motors, brushless DC motors and more online.
Group Therapy
I am going to try the second cue list and sub master idea.. I will post a reply after trying it out..
