Help please.
I'm new to Freestyler and it looks potentially ideal for my simple stage show.
I downloaded it and ticked for EasyView at the same time.
There's a message that says one MUST finish the EasyView installation before completing the Freestyler installation. And that one should put the EasyView download in the Freestyler folder.
My first problem was that there was no Freestyler folder when I need to give a location for EasyView. But I created one and carried on. EasyView appeared to download and then Freestyler also and I ended up with one Freestyler folder with all of Freestyler in it and a couple of EasyView files.
I have the 3D button in Freestyler but clicking it does nothing.
In the Freestyler folder the only things that seem EasyView-related are
EasyView.ini and
EasyView.exe files.
Anyone got any ideas why it's not linked?
Freestyler EasyView button not working
- FreeStyler Version: 4.1.6
- FreeStyler Version: None
Re: Freestyler EasyView button not working
I'd go on the actual website and see if you can get a download there for Easyview, you then should be able to link them together.
