Beam + spot China 120w Topic is solved
TOZESURF
Has mastered Fixture Creator
FreeStyler Version: 3.5.7
Post by TOZESURF »
Theres ´s anyone who have the fixture .pff file for those Moving head´s please ?
I´m a beginner and i can make the fixture creator ! :( I can do it ...
Thanks from bottom of my heart
MrSleeps
FreeStyler Version: 4
Re: Beam + spot China 120w
Post by MrSleeps »
If you post the manual I'll take a look
TOZESURF
Post by TOZESURF »
Thanks my friend #MrSleeps
Heres are the chanells
MrSleeps
Post by MrSleeps »
Give me a day or two and I'll upload a fixture file for you..
TOZESURF
Post by TOZESURF »
Thanks my friend. Thanks a lot
TOZESURF
Post by TOZESURF »
MrSleeps wrote: 21 Jun 2024, 01:06 Give me a day or two and I'll upload a fixture file for you..
My brother meanwhile i tryed to make but without sucess.. Can you really do it ?
TOZESURF
Post by TOZESURF »
TOZESURF wrote: 02 Jul 2024, 07:57
Can you really help me ?
TOZESURF
Post by TOZESURF »
Can anyone help me please ? I need the fixture .pff for those moving head´s 120w china Beam+spot
TOZESURF
Post by TOZESURF »
MrSleeps wrote: 16 Jun 2024, 23:05 If you post the manual I'll take a look
my friend you can help about this ?
TOZESURF
Post by TOZESURF »
MrSleeps can you help me ? Please
TOZESURF
Post by TOZESURF »
Is ANYONE that can help about this fixture ? Please ?
TOZESURF
Post by TOZESURF »
Please ...
TOZESURF
Post by TOZESURF »
anyone can help me ?
MrSleeps
Post by MrSleeps »
That should get you started.
If it doesn't work, it's up to you to fix it. I don't have the light so can't test.
Unknown Chinese Beam - Spot 120w.pff
(84.3 KiB) Downloaded 1977 times
DJCEKO
Twitter: nop
Instagram: nop
Post by DJCEKO »
Hello, I bought four UKING ZQ 02061, where can I find or download the fixture profile so I can control them with FREESTYLER DMX.. thank you!!
FreeStyler Version: 4.1.7
Post by Rod_Horning »
Attached is my attempt at a fixture profile for your instrument. I have also attached the user manual. As I so often see with these instruments the information in the user manual is sparce. There are no images of the gobos and there is no information about the colors. Also, I have no idea what is meant by Strip Effect.
ZQ02061.pff
(33.48 KiB) Downloaded 1994 times
U King ZQ02061 Mini Gobo Moving Head Light User Manual.pdf
(2.04 MiB) Downloaded 1990 times
DJCEKO
Twitter: nop
Instagram: nop
Post by DJCEKO »
Thank you very much,my friend, I made several unsuccessful attempts, but without effect!! I wish you all the best!!
DJCEKO
Twitter: nop
Instagram: nop
Post by DJCEKO »
