Unlink the chase speed from submasters
lightman1990
FreeStyler Version: 3.6.3
Post by lightman1990 »
I have 2 submasters. One controlls the dimmer (and dimmer effects) of the MH's (SM1) and the other of the PAR's (SM2). When i change the dimmer effect of the MH's, e.g. from "full on" to "odd on off", the chase speed of the SM2 is resetted to 100%.
I don't want that chase speed is effected at all when i switch to another sequence inside a submaster. (hope i understand this correctly and use the correct terms)
I already tried to play with functions like "ignore masterspeed" and "do not restore channels" ???
FreeStyler Version: 4.1.7
Re: Unlink the chase speed from submasters
Post by Rod_Horning »
You should report/request this on the bug tracker / feature request site:
https://www.freestylersupport.com/bugs/login_page.php
perrip
Commited FS Forum helper
Post by perrip »
I may not be understanding the question, but I think what you want to do is right click in the submaster box and check the spot that says Leave Speed 'as is'
