Hi everyone, I have just just started dabbling with DMX at home for Halloween haunts.
I have a Prolights Equinox Microbar Multi System.
This is the product:
https://www.prolight.co.uk/Catalogue/Pr ... s/EQLED136
The manual can be found here and also attached:
https://www.manualslib.com/manual/12527 ... ed136.html
I am a non-coder (DMX itself is the limit of my understanding!) so I don't think I have the time to learn how to create profiles. In case anyone else can, I would like one please...
This topic also relevant but I think not in the requests section:
viewtopic.php?p=35409
Prolight Equinox Microbar Multi
berto2002
- FreeStyler Version: 4.1.6
Equinox Microbard manual qled136.pdf- (1.44 MiB) Downloaded 140 times
MrSleeps
Re: Prolight Equinox Microbar Multi
You don't need to be a coder to make a fixture file, small learning curve but you'll have it sussed within the hour. The tutorial is pretty self explanatory and you just need to match what the manual says to what the fixture creator boxes are asking for to get a basic fixture file up and running.
As I said in the other thread, split the lights in to different fixtures, you'll have more control.
You'll need 1 fixture for "effect 1":
Total Channels: 5
Click enable cmy/rgb then again click rgb values
Red Channel: 1
Green Channel: 2
Blue Channel: 3
CW Channel: 4
Not sure what you'd need to put for rotation, I'm not at my laptop so can't remember the exact name of the box you need to fill out.
LED Pars are roughly the same as effect 1 and as is effect 2. Make sure you change the Total channels bit to match the number of channels the fixture has.
Total Channels: 5
Red Channel: 1
Green Channel: 2
Blue Channel: 3
CW Channel: 4
