Quit question should be optional
kozaka
FreeStyler Version: 4.1.6
Post by kozaka »
It would be great, if we could set in the settings, that in time of Quit (Exit), should come the "Are you sure you want to quit?" question or not. To be able to shut down the PC without stuck with this question.
Re: Quit question should be optional
Please recommend it as a feature request using the bug tracker system (different registration required)
Return to “Ideas and Remarks”
