Install problem Autocad
smitske96
Post by smitske96 »
I needed to reinstall Freestyler DMX (latest version). However, when all is installed and I click the freestyler DMX desktop shortcut, it wants to install Autocad 2020. This gives the problem that it can't find the correct path and I can't decline to installe autocad 2020.
Reinstalling freestyler dmx gives the same outcome.
Did anyone have a comparable problem and maybe a solution or some tips?
Glenn Garcia
Re: Install problem Autocad
Post by Glenn Garcia »
smitske96 wrote: 19 Jul 2023, 22:48 Hi,
If you regularly use both Freestyler DMX and Autocad 2020 at the same time, you can check Autocad 2020's keyboard shortcuts and change them to avoid conflicts with Freestyler DMX.
With its intuitive interface and powerful search feature, Apktome allows you to easily find and download your favorite gaming app.
Return to “Ideas and Remarks”
