Cue Window Sequence Field Length
hardtroy
- FreeStyler Version: 4.1.6
- Instagram: hardtroy1
In the cue window why is the sequence file name field so short? It's only like 26 characters wide. This has caused a issue for me cause I can't see the whole file name which describes my sequences. Been using transparent mode sequences for different groups of lights so I can mix and match color sequences with position sequences. I've setup a library with file names that describe my sequences. The cues are working great but It can be confusing when it cuts off the sequence file name at 26 characters in the cue. Thanks
