USB DMX512 driver
mariance
FreeStyler Version: 4.1.6
USB DMX512 driver
Post by mariance »
Hi! I'm trying to figure how to make this weird usb dmx controller work... I cant find drivers for it anywhere and the device manager shows this
https://prnt.sc/I1JD1xxEntyY
The hardware ids of the controller is this
https://prnt.sc/o1O3Eg5_5nkz
the USB DMX512 is listed in freestyler but it gives an error
"DHC_OPEN - DHC_ERROR_NOTOPEN"
Im not sure what driver do I need to install. chips inside are sn75176bp and PIC16C745. not sure if that helps.
Motsik
Re: USB DMX512 driver
Post by Motsik »
Give a photo of the dmx controller
Try this driver.
jlroco
FreeStyler Version: 4.1.7
Post by jlroco »
MAriance, were you able to solve the driver problem? All the links for this driver are down.
In Device Manager, it says "USB DMX512".
Mine uses the same chip and memory sn75176bp and PIC16C745.
Post by Rod_Horning »
Attached is the ZIP file from the link posted by Motsik
I STRONGLY suggest you run virus scans on the file.
51860118-Support-106093-2.120-eurolite-usb-dmx512-interface-update-adaptor-Windows-driver-de_en.zip
(1.99 MiB) Downloaded 192 times
Return to “DMX Interfaces”
