'Crystal ball' type fixtures
PeteW1959
FreeStyler Version: 3.6.50
I Use FreeStyler for: Band
Post by PeteW1959 »
Is it possible to create this type of fixture in Magic 3D?
It is like this (but not this actual model)
https://tinyurl.com/2p926aht
I want to have a go myself (I've already done a couple of scanners and LED PARs) but don't want to spend hours trying to achieve the impossible!
Re: 'Crystal ball' type fixtures
Not sure about magic 3d they are effectively act like mirror balls though so you should be able to grasp what they look like with your imagination 😝
