Is it possible to have more than the limiting 20 sequences? I have used up the full 20 but would like to create more. I usually trigger these off the touchscreen then tap tempo them to the song, but would love to be able to creat ea whole load more
Dave
Sequences feature request
DavidT1971
- Just started using FS
- FreeStyler Version: x2 4.1.1
- FreeStyler Version: 4.1.7
Re: Sequences feature request
If I remember correctly that can be changed in the freestyler.ini file. Number=nn under NumberOfScenes.
I remember that one user had a "phantom install" of Freestyler (ie. had 2 Freestyler installs) and had to change the correct freestyler.ini file.
If you give it a try please update this thread with the results.
- djSupport
You can create one movement sequence and change the colours, gobos, strobe etc from the override buttons
DavidT1971
"If I remember correctly that can be changed in the freestyler.ini file. Number=nn under NumberOfScenes.
If you give it a try please update this thread with the results."
Will give it a try later, although im not sure how the additional sequences will translate when I go to add buttons to the touch screen for them. At least with over ride buttons you can specify the button number when over 20 rather than selecting from the dropdown list, sequences dont seem to have an "n" button to say what sequence it would be.
DavidT1971
thanks, yeah I have done that for some, but as lighting is my 2nd task and sound my main, I want to be able to just hit whatever sequence I think would suit the song playing, tap the tempo in and then leave it to it, other than a few over rides of strobe etcdjSupport wrote: 01 Feb 2023, 22:21 You can create one movement sequence and change the colours, gobos, strobe etc from the override buttons
DavidT1971
Sorry, event replied in a while (been up to my neck in it), so yeah the above idea doesn't work for me, sorry. the physical amount of sequences can't be increased in the ini etc - probably a limitation on the sequence windowDavidT1971 wrote: 02 Feb 2023, 15:50 "If I remember correctly that can be changed in the freestyler.ini file. Number=nn under NumberOfScenes.
Dave
