There's a great fixture creator tutorial here:
https://www.freestylersupport.com/wiki/ ... oving_head
It takes you step by step through the process of making a new moving head fixture.
You'll need the manual that came with the light, you'll need to choose between the 5, 9 or 11 channels mode and then match the channels mentioned in the dmx settings in the manual to what the boxes are in the Fixture Creator, not all of them will need to be filled out (you will only need to fill out the number of channels, gobo channel, colour channel, pan & tilt, dimmer/intensity and strobe).
It's not a complicated light, shouldn't take you too long to go through the tutorial I posted (change the values it says with your own) and get a fixture file made.
Give it a try, if you get stuck export the fixture file you have created by following the tutorial (using your lights settings) and upload it to here for others to have a look at and help.
Or use the fixture creation service to have one made for you..
