minimize button for Touchscreen UserInterface 2
GiovanniG
Post by GiovanniG »
Hi mates, I've a compact Windows device with touchscreen, and I would use it as control for lights and audio player, I would get advance of the touchscreen interface to change lights effect, but I would also have the chance to easly go back to desktop, and switch it on again. At this moment I need to press "minimize", which is a bit difficoult because the screen is small, it's located up, not big size, and I'm afraid to touch shutdown. Is it possible to have a minimize button in the touchpanel? I've searched but on the list it is not present.
Now I press minimize and see the Freestyler, I minimize it too to see desktop, then I press on freestyler icon and I see the touchpanel again. It would be interesting to have 2 minimize, minimize to Freestyler and minimize to Desktop, if possible, thank you!
Re: minimize button for Touchscreen UserInterface 2
The bug tracker also serves as a feature request system, pop it on there
GiovanniG
Post by GiovanniG »
I did, thank you :)
jimmeri
FreeStyler Version: 4.1.2
I Use FreeStyler for: Film
Post by jimmeri »
Hey guys, first of all, thanks for this free and useful program, FreeStyler is fantastic!
I just want to say that I would also like to see such a button, but the bug tracker is a good solution in this case too!
I am interested in astrology and everything mystical. For example, from the Leo compatibility chart, I recently learned that my best match is Sagittarius.
GiovanniG
Post by GiovanniG »
I would be also important to have a button on the bar to open the Touchscreen UserInterface 2 quickly, at this time we need to go to setup and enable it (on window mode). This panel is really useful and in my opinion should be an essential part of the program, easy to open and close. Thank you
Is there not a keyboard shortcut?
GiovanniG
Post by GiovanniG »
djSupport wrote: 04 Feb 2023, 19:34 Is there not a keyboard shortcut?
I have no ide about it, I'm using a small windows PC with touchscreen only, no keyboard, so I would like to have the chance to minimize window and have it back by pressing something (not too small because the screen is 10" only)
Return to “Ideas and Remarks”
