Ipad APP?
Geniouz
Ipad APP?
Post by Geniouz »
Hello,
what is the most current or best way to use the Freestyler connection from PC to Ipad. I have everything set up on my pc and would like to use the ipad simply as a controller. With Android it works without problems but it must also be possible with an ipad.
Are there other programs and if so how do I set them to play a connection and all the preset programs for the light?
thanks a lot
Geniouz
Re: Ipad APP?
Post by Geniouz »
wow really nobody answers here or can give me an answer? then i should probably change the software instead of getting a reasonable solution from the publisher of this software :-(
xever
Twitter: www.120db.uk
Re: Ipad APP?
Post by xever »
There is no Ipad application that is kept up to date.
Buy an Android Tablet because the Android app is the best
Get the Freestyler Remote App
Freestyler 3rd Party Addons
www.120db.uk
Re: Ipad APP?
Geniouz wrote: November 7th, 2022, 2:32 pm wow really nobody answers here or can give me an answer? then i should probably change the software instead of getting a reasonable solution from the publisher of this software :-(
The 'publisher' makes this software in his spare time whilst juggling a real job and family life! And it's free! Apps that connect to FreeStyler are made by the community and so are 3rd party and have nothing to do with the FreeStyler developer. The only consistent app developed and maintained is the FreeStyler android app.
Djpa3k
FreeStyler Version: 4.1
Re: Ipad APP?
Post by Djpa3k »
Return to “iOS (iPhone & iPad)”
