Hello, I have a somewhat complex problem, I have 16 - parleds, all being the same and from the same manufacturer.
it happens that some of these parleds(3) are not working with Freestyle, however they work with Q Light perfectly, the DMX command arrives correctly, the channels are separated, even putting in channels that another parled that is working correctly the 3 parleds do not work , but they all work with the Q light controller.
would anyone know a solution to this problem?
I've tried all sorts of freestyle configurations and I couldn't get it to work.
follow channel specifications
Channels
1 - DIMMER
2 - RED
3 - GEEN
4 - BLUE
5 - STROBE
6 - EFFECTS
I don't understand a lot of English, I'm using google translator, in case something doesn't work, that's why.
BUG - MALFUNCTION
giovanicuquil
- FreeStyler Version: 4.1
GiovanniG
Re: BUG - MALFUNCTION
change the dmx values manually, if you know what you are doing and there is no effect you may have 2 problems:
the controller you are using with freestyler doesn't work properly
You don't have right connections on the DMX bus, check it, check if the pin 2 and 3 of XLR connector maybe are somewhere reversing (they should not), at the end of line put a 120ohm resistor between 2 and 3
