I have recently done a new install of Freestyler DMX V4.1.1 and associated Magic 3D. I have successfully created a layout in Magic 3D and one in Freestyler. When I initially launch Freestyler, and then Magic 3D, everything seems to work fine. I am able to fully control the simulated lights. However, after a short period, Freestyler quits sending DMX. If I look at the "output" window I see no movement in values no matter what I do with fixture control. The only solution is to delete each fixture in Freestyler and then add it again. After doing this, things work again for a short time, but then the same thing happens again. Stopping and starting Magic 3D and Freestyler has no effect. Only recreating fixtures seems resolve the issue - though only for a short period of time.
Has anybody else seen this problem?
DMX stops working
trindt
- FreeStyler Version: 3.5.9
- djSupport
Re: DMX stops working
Not seen it reported, report this on the bug tracker if you think it's a bug. Are your sequences looping?
