Robe ClubSpot 150CT Mode 1/2/3/4 (Moving head)
FreeStyler Version: N/A
Post by remco_k »
(new user of Freestyler checking in here) :mrgreen:
Fixture files for: Robe ClubSpot 150CT Mode 1/2/3/4
Tested: No
Gobos: Exact copy from gobo wheel
Colors: Should be near real life
Default mode: Mode 1 (The fixture defaults to mode 1 if it is new from the factory).
Recommended mode: Mode 1 or 2.
Website of manufacturer: http://www.robe.cz/ Direct link to fixture
I did not test these files yet. Because I don't have these (or any) fixtures by myself.
I will be able to test them in december 2008 (lightshow with rented equipment). But for now, here are the exported fixture files for the Robe ClubSpot 150CT in all available DMX modes this fixture supports. Mode 1(8ch),2(8ch),3(6ch) and 4(6ch).
Mode 1 and 2 are 16 bit Pan/Tilt modes.
If by accident anybody can test these fixture files (only mode 1 is enough), then I will be greatfull.
I really have no idea if these fixture files will work in reallife, I hope and think they do. Never used Freestyler on a real DMX line yet. That will be done in december 2008, as a test. An SGM DMX controller will be the backup. :D
Robe ClubSpot 150CT M4.pff
Robe ClubSpot 150CT Mode 4 (6 DMX channel)
(120.18 KiB) Downloaded 145 times
Robe ClubSpot 150CT M3.pff
Robe ClubSpot 150CT Mode 3 (6 DMX channel)
(120.19 KiB) Downloaded 137 times
Robe ClubSpot 150CT M2.pff
Robe ClubSpot 150CT Mode 2 - 16 bit pan/tilt (8 DMX channel)
(120.21 KiB) Downloaded 129 times
Robe ClubSpot 150CT M1.pff
Robe ClubSpot 150CT Mode 1 - 16 bit pan/tilt (8 DMX channel)
(120.21 KiB) Downloaded 150 times
Reason: Updated link to robe website
Re: Robe ClubSpot 150CT Mode 1/2/3/4 (Moving head)
Post by remco_k »
I have tested the "Robe ClubSpot 150CT M1.pff" (Mode 1) and it works perfectly.
Knowing that, the other files should work just as good.
Return to “Robe”
