Freestyler 4.0.1 Topic is solved
Freestyler 4.0.1
Is it possible to download 4.0.1? Later i will try the latest version, butfor installation on a laptop i want to have the same version as on my pc.
- FreeStyler Version: 4.01
Re: Freestyler 4.0.1
you are smarter to update the PC to 4.1
Version 4.01 was removed because it had many problems. i would not trust 4.01 at all
just install over the top, no export or removal necessary. Always make a backup file before upgrading
tanx, it works.
